{"database": "crashreports", "table": "crash_reports", "is_view": false, "human_description_en": "where dcc contains \"Wrong way\" and \"retrieved\" is on date 2022-04-27", "rows": [["22000321", "2022-04-20T07:21", "2022-04-20", "07:21", "197 CALIFORNIA ST", "WEST 197 CALIFORNIA ST", null, 0, 30, 0, 0, "MV1 stated they were travelling w/b on California St when MV2 \"was right behind me, crossed the double yellow lines to pass me, nearly went head on with someone else, cut back and hit the front of my car\" causing minor damage. MV2 was described as a Silver Infiniti that fled on Bridge St towards Watertown. A canvass of the area was conducted yielding negative results. No tow was required and no injuries were reported.", "[]", "[\"Wrong way\", \"Reckless driving\"]", "[8, 10]", "/static/reports/22000321.pdf", "/static/images/22000321.png", "197 California St, Newton, MA 02458, USA", "42.3651092", "-71.1963023", 0, "2022-04-27T16:27:13.187613"]], "truncated": false, "filtered_table_rows_count": 1, "expanded_columns": [], "expandable_columns": [], "columns": ["case_number", "datetime", "date", "time", "address", "street1", "street2", "intersection", "speed_limit", "hit_run", "violation_cited", "narrative", "keywords", "dcc", "dcc_code", "report_url", "image_url", "geocoded_address", "latitude", "longitude", "manual_geocode", "retrieved"], "primary_keys": ["case_number"], "units": {}, "query": {"sql": "select case_number, datetime, date, time, address, street1, street2, intersection, speed_limit, hit_run, violation_cited, narrative, keywords, dcc, dcc_code, report_url, image_url, geocoded_address, latitude, longitude, manual_geocode, retrieved from crash_reports where :p0 in (select value from json_each([crash_reports].[dcc])) and date(\"retrieved\") = :p1 order by case_number limit 101", "params": {"p0": "Wrong way", "p1": "2022-04-27"}}, "facet_results": {}, "suggested_facets": [{"name": "datetime", "type": "date", "toggle_url": "https://crashreports.newtonmoves.org/crashreports/crash_reports.json?dcc__arraycontains=Wrong+way&retrieved__date=2022-04-27&_facet_date=datetime"}, {"name": "date", "type": "date", "toggle_url": "https://crashreports.newtonmoves.org/crashreports/crash_reports.json?dcc__arraycontains=Wrong+way&retrieved__date=2022-04-27&_facet_date=date"}, {"name": "retrieved", "type": "date", "toggle_url": "https://crashreports.newtonmoves.org/crashreports/crash_reports.json?dcc__arraycontains=Wrong+way&retrieved__date=2022-04-27&_facet_date=retrieved"}, {"name": "dcc", "type": "array", "toggle_url": "https://crashreports.newtonmoves.org/crashreports/crash_reports.json?dcc__arraycontains=Wrong+way&retrieved__date=2022-04-27&_facet_array=dcc"}], "next": null, "next_url": null, "private": false, "allow_execute_sql": true, "query_ms": 852.6818864047527}
