12 rows where keywords contains "Speed" and "retrieved" is on date 2020-12-27
Suggested facets: date, intersection, speed_limit, hit_run, violation_cited, keywords, dcc, dcc_code, retrieved, datetime (date), date (date), retrieved (date), keywords (array), dcc (array)
Case
number:
EDDY ST & WASHINGTON ST
limit:
Violation
cited:
On 09/30/2020 at approximately 19:32hrs members of the Newton Police Patrol Bureau responded to a motor vehicle crash near the intersection of Washington St and Eddy St. After an initial investigation of the crash the Patrol Bureau secured the crash scene and called in the Newton Police Traffic Bureau to investigate. At approximately 19:45hrs Sgt. Devine, Ofc Wilson and I (Ofc Schlegel) from the NPD Traffic Bureau responded to the scene to investigate. Upon arrival to the scene I was met by Ofc Kane of the NPD Patrol Bureau. Ofc Kane stated that the crash was located in the driveway of 74 Eddy St and that it involved a Ford F350 pickup striking two parked cars. Ofc Kane stated that the operator identified as Kyle Butler had already been taken to Newton Wellesley Hospital by Cataldo EMS for injuries. . Upon approaching the crash scene I observed the following: The crash occurred at night time hours at approximately 19:32EST near the intersection of Washington St and Eddy St. Both Washington St and Eddy St are public ways in the City of Newton. The weather conditions at the time of the crash were a dark and clear with a temperature of approximately 60 degrees F. Washington St is a four lane undivided roadway (2 westbound travel lanes and 2 eastbound travel lanes). Washington St lighted roadway which has concrete light poles on both the westbound and eastbound sides. Washington St was under construction at the time and had a base coat of asphalt applied. At the time of the crash Washington St did not have any painted lane markings due to ongoing construction. Washington St is separated from the road sides on both the eastbound edge and the westbound edge with fixed granite curbing. The roadway also had several orange traffic barrels and traffic cones located edges of the eastbound and westbound lanes. Affixed to the light poles and the traffic barrels were temporary no parking signs for the ongoing road construction. At the time of the crash no road construction activities were taking place. No major debris or other obstructions were observed in the roadway. Washington St is a major roadway in the City of Newton and travels west to East across the entire City of Newton. This area of Washington St where the crash occurred is in between West Newton Square and Newtonville Square, this area has a posted 35 MPH speed limit. Both West Newton Square and Newtonville Square are densely populated with several businesses and residential areas. The section of Washington St where the crash occurred is also traveled frequently by pedestrian, bicycle and motor vehicle traffic. At the time the crash occurred 19:32hrs This area of Washington St is still a heavily travelled roadway. I observed Vehicle 1 described as a 2003 Ford F350 color white (MA Reg 5DT664) located in the driveway of 74 Eddy St. 74 Eddy St is a multi-family dwelling house located on the corner of Washington St and Eddy St. The driveway of 74 Eddy St is on the Washington St side. Vehicle was faced easterly across the driveway. I observed Vehicle 1to have extensive damage to the entire vehicle including but not limited to the enclosed cab area, cab roof and all windows, front end, rear end, along with both driver and passenger side. I also observed city of Newton owned concrete traffic light resting on top of the cab area of Vehicle 1. Upon further observation of Vehicle 1 it appears that both front tires and rims were flat, heavily damaged and had little to no tread left. Both front tires were worn down to the interior steel belt. I also observed that Vehicle 1 did not have a valid inspection sticker. Located to the immediate front of Vehicle 1 and resting on the front end was a white fence which had damage consistent with the impact of a motor vehicle. Immediately to the driver's side of Vehicle 1 was Vehicle 2 described as a 2007 gray Subaru Forester (MA Reg 45D610. Vehicle 2 was facing westerly across the driveway. Vehicle 2 had extensive damage to the driver's side front end, rear end, in addition to the entire driver and passenger sides. At this time Vehicle 2's drivers door was in contact with Vehicle 1's drivers door. Both drivers doors could not be opened.The damage to Vehicle 2 appeared to be consistent with impact from another motor vehicle. To immediate passenger side of the Vehicle 2 I observed Vehicle 3 described as a 2011 Toyota Rav4 color black (MA Reg 47XB99). Vehicle was facing in an easterly direction across the driveway. I observed the Vehicle 3 to have extensive damage to driver's side rear quarter panel, passenger side front quarter panel and front end. Also observed was damage to south east corner of the dwelling of 74 Eddy St. This area of the dwelling is located adjacent to the drive way. The damage appeared consistent with the impact caused by a motor vehicle. Also observed were large amounts of debris located in the area of the crash which included the sidewalk, yard and the driveway of 74 Eddy St. The debris included pieces of concrete which appeared to have been dislodged from the concrete light pole. A city of Newton no parking sign was lying in the yard of 74 Eddy St. This parking sign would have been attached to the concrete light pole due to ongoing road construction on Washington St. I also observed two tire marks on a curb stone located next the westbound lane of Washington St. These tire marks were in front of the residence of 74 Eddy St and were to the immediate left of a storm drain. The tire marks were consistent with being struck by a motor vehicle. In between the tire marks and just after the curb there was a hole in the ground with wires sticking out of it. This hole appears to be the location the concrete light pole was located prior to impact. Tire marks were located on Washington St traveling from the east bound lane easterly across the westbound lane and ending at the tire marks on the curb. The total length of the tire marks was approximately 190 feet. After conducting an on scene investigation it appears that Vehicle 1 from the start of the tire mark in eastbound travel lane of Washington St traveled 190 feet in the easterly direct across the westbound lane of Washington St and impacted the curb in front of 74 Eddy St. The tire marks had lateral striations almost the entire length indicating that the front tires were rolling and sliding with little to no braking prior to impact with the curb. After impact with the curb Vehicle 1 exited the roadway, struck a concrete light pole. Vehicle 1 then traveled over a sidewalk, across the yard of 74 Eddy St and into the driveway of 74 Eddy St. Located in the driveway of 74 Eddy St were Vehicle 2 and Vehicle 3. Vehicle 2 was parked facing toward the rear of 74 Eddy St. Vehicle 3 located to the passenger side of Vehicle 2 and was parked facing towards Washington St. When Vehicle 1 entered the driveway it struck Vehicle 2. The force of the impact of Vehicle 1 striking Vehicle 2 caused Vehicle 2 to strike Vehicle 3. The force of the impact of Vehicle 2 striking Vehicle 3 caused Vehicle 3 to strike the southeast corner of the dwelling located at 74 Elliot St. Vehicle 1 continued across the drive way and struck a white fence before coming to final rest. Vehicle traveled a approximately 55 feet from when it initially struck to the curb till final rest. No other injuries were reported on scene. All involved vehicles were towed from the scene by Tody's Towing. After the investigation the operator of Vehicle 1 Kyle Butler was issued Citations T2015882 and T2015883 for: Mgl 90/24/O Recklass Operation of a Motor Vehicle Mgl 89/4B/A Failure to Operate in the Right Lane Mgl 90/20 Failure to Submit a Motor Vehicle for Inspection Mgl 90/7 Defective Equipment (worn front tire treads) Mgl 90/13A Failure to wear a seatbelt An immediate threat form was also filed with the MA RMV. Please see incident report #200440 regarding charges.
Report
url:
url:
Case
number:
130 VINE ST
limit:
Violation
cited:
On Thursday 10/29/20 at approximately 0541 hours while assigned to marked unit n499 I was dispatched to the area of 130 Vine Street for a report of a single vehicle roll-over crash. Upon arrival myself and n496(Ofc. Howes) observed a white SUV on its roof facing westbound in the eastbound lane of Vine Street (a public way owned, operated and maintained by the City of Newton). Upon our arrival Newton Firefighters had extracated the operator, (FOSTER Isabelle), who was sitting on a large rock in the front yard of 130 Vine Street. FOSTER was visibly upset, but didnt appear to have any major injuries. I asked FOSTER what happened and she stated she was travelling from Westgate Rd in Boston on her way home to Wellesley. She took a right turn onto Vine Street from LaGrange Street and began travelling westbound. FOSTER stated that she was travelling too fast and didnt realize how the road curved causing her to veer off the road and strike a large tree in the front of 130 Vine Street. FOSTER was travelling at a speed fast enough to cause the vehicle to flip onto its roof in the opposite lane of traffic. FOSTER admitted to me she was travelling too fast on the road. Vine street is a winding road that is not very well lit. Speed limit on the road is 20mph and its estimated FOSTER was travelling at least 30-45mph. The speed coupled with FOSTER's lack of familiarity with the area and her inexperience driving were all contributing factors to the crash. FOSTER was issued Massachusetts Uniform Citation T2012909 with the following civil motor vehicle infractions; C90 s18 SPEEDING (Posted) C89 s4a Marked Lanes Violation. FOSTER was transported to Beth Israel hospital by the medics and I was unable to issue the citation in hand at the time of the crash. Due to FOSTER's age (17) I also wanted to notify her parents and meet with them and FOSTER upon her release from the hospital. At approximately 1700 Hours I met with Scott Foster(Father) in person, Jodi Foster (Mother) and Isabelle foster via cell phone (speaker phone). I discussed the charges with all parties and explained the citation to Isabelle. Citation was given in hand to her father, Scott Foster and brough the citation to Isabelle.
Speeding, Inattention
Report
url:
url:
Case
number:
KENSINGTON ST & WATERTOWN ST
limit:
Violation
cited:
MV1 stated he was travelling straight ahead when MV2 "slammed into me at what felt like 80mph." MV1 sustained heavy damage to the driver's side rear, however did not require a tow. MV2 stated he was "only doing 45mph" and thought MV1 was "going faster than they were and I couldn't stop" subsequently causing heavy front end damage. MV2 was removed from the scene and the operator was cited for speeding.
Citation, Speed
Speeding, Reckless driving
Report
url:
url:
Case
number:
PEARL ST & JACKSON RD
limit:
Violation
cited:
On November 1st, 2020 at approximately 14:02 hours while assigned to N491 I responded along with Newton Fire and Medic One to the intersection of Pearl St @ Jackson Rd for a MV crash with minor injuries. On my arrival I first observed in the intersection a green colored Volkswagon with Vermont tag,HPK270 with extensive damage. The other involved vehicle a white Jeep Wrangler, bearing Ma tag, 8WK846 was located on the property of the Lincoln Elliot School, 191 Pearl St, also with extensive damage. The operator of the green Volkswagon was identified as Viorel Marin. He stated he was going E/B on Pearl St and was approaching the intersection of Jackson Rd when the light had turned green. As he was entered the intersection vehicle #2 came from his right side(N/B) on Jackson Rd at, according to him, a high rate of speed causing his vehicle to collide with the Jeep. He doesn't remember much after that. I observed a small cut to his right knee and later he showed me a small abrasion to his forehead. All his air bags had deployed on contact with vehicle #2 . I located the operator of the Jeep who was sitting on the ground being assisted by an unidentified women(not a passenger). She appeared shaken but had no visible signs of any serious injury from the crash. She identified herself as Tara Feeley. According to Ms Feeley she had been travelling N/B on Jackson Rd and was attempting to continue straight across the intersection of Pearl St when she was struck by vehicle #1 in the intersection. The impact caused her vehicle to flip over unknown amount of times finally landing on the property to the Lincoln Eliot School. Based on operator #2's statements, my observations of the scene, damage to her MV, it appeared her vehicle after contact with vehicle #1, flipped over N/B across the intersection first hitting the traffic light on the northeast corner, additionally making contact with the utility pole just east of the traffic light before finally landing right side up on the property of the Lincoln Eliot School. She reported climbing out her passenger side window when her vehicle finally stopped. She said,"she was lucky she had her seat belt on". I agreed. Ms Feeley also reported that she was sure that her light was green as she entered the intersection. I attempted to locate any possible witnesses from the crowd that were gathered near the crash site. There were two that heard the crash but none that actually saw what happened. I couldn't locate any cameras near the intersection. Both vehicles were towed from the scene due to the extensive damage/both totaled. Both operators had minor injuries and both declined to be transported to the hospital. They signed patient refusals. Officer Danny Anderson later took several pictures of the crash scene and the all the property damage. Both utility companies were notified. The camera disc was placed in the technology bureau mailbox.
Report
url:
url:
Case
number:
TREMONT ST
limit:
Violation
cited:
Operator of vehicle one ( 2016 Infinity MA reg 3YD266 ) Miram Qualter, stated on 11/05/2020 at 10:28 hours while driving south bound on Waverley Ave near the intersection of Tremont St " the light was turning " as her vehicle entered the intersection. Both Tremont St and Waverly Ave are public ways in the City of Newton. Qualter stated that she was driving into solar glare and did not see any traffic in the intersection as she proceeded into it. Qualter stated that she believed that she still had the right of way and that traffic on Tremont St had a red light. Qualter stated that she did not see vehicle two until the time of impact . Qualter stated that she was not injured in the crash. Qualter's vehicle had major damage to the front driver's side windshield and front driver's side quarter panel. Operator of vehicle two Keith Ward stated that he was riding his Itraxx Cruze motor scooter west bound on Tremont St near Waverley Ave on 11/05/2020 at 10:28 hours. Ward stated that west bound traffic had a green light and he proceeded into the intersection. Ward stated that as he was approximately halfway into the intersection when vehicle one crashed into the right front of his vehicle. Ward stated that he was ejected from his motorcycle and onto the hood of vehicle one. Ward was wearing a helmet and his head had contact with vehicle one's driver side windshield causing substantial damage. Ward was evaluated by Newton Medic Unit 3 and refused medical treatment. Ward signed a patient refusal form provided by the medics. Ward had visible head lacerations that caused minor blood loss. Witness Jose David stated that he was riding on a motor scooter behind Ward. David stated that west bond traffic on Tremont St had a green light and that vehicle one did not stop at a red light. Based upon statements made to me and my observations of the involved vehicles, I issued Qualter MA Citation T2016100 and cited her for a violation of MGL 89/9 , failure to stop at a red light. I took photos of both vehicles and the disk was downloaded by the NPD's IT Bureau. Both vehicles were towed by Tody's Towing, and I filled out towed motor vehicle forms. During my investigation of this crash I discovered that the motor scooter that Ward was operating is classified as a motorcycle, because it's cylinder capacity exceeded 50cc. Ward's vehicle speedometer indicted that it's top speed was 50 MPH, and it's VIN tag stated it was a motorcycle. I observed that there was no license plate on Ward's vehicle and he stated to me that it was unregistered. A check of the MA RMV had no record of Ward's vehicle and also revealed that Ward's driver's license was suspended on 12/04/2018. It was also revealed from a of the MA RMV data base that witness Jose David's driver's license statue is expired non renewable as of 01/23/2017. David stated to me that he did not have a driver's license. I also discovered that David's motor scooter was classified as a motorcycle, because as with Ward's vehicle it also had a cylinder capacity exceeding 50cc. David stated to me that his vehicle was unregistered. I issued David MA Criminal Application T2015901 and cited him for violations of MGLs 90/10, operation of a motor vehicle with out a license, 90/34j uninsured motor vehicle and 90/9 , unregistered motor vehicle. I issued Ward MA Criminal Application T2015902 and cited him for violations of MGLs 90/23 , operating a motor vehicle after suspension, 90/34j, uninsured motor vehicle and 90/9 unregistered motor vehicle. I filled out an Operating After Suspension Affidavit and faxed it to the MA RMV Driver Control Unit.
Report
url:
url:
Case
number:
AUBURNDALE AVE & LEXINGTON ST
limit:
Violation
cited:
Operator of vehicle one ( MA reg 1HK920 2010 Toyota Tacoma ) Brian Robidoux stated that on 11/06/2020 at 14:49 hours he was driving west bound on Auburndale Ave near Lexington St. Both Auburndale Ave and Lexington St are public ways in the City of Newton. Robidoux stated that west bound traffic had a green light at the intersection of Lexington St, and that north and south bound traffic on Lexington St had a red light. Robidoux stated that as he turned his vehicle left into the north bound lane of Lexington St was hit on the front driver's side quarter panel by motorized bicycle that did not stop for the red light. Robidoux stated that he was not injured in the crash and his vehicle did not required a tow. The operator of the motorized bicycle Arif Ahmed stated that he was riding north bound on Lexington St on a Lectric XP motorized bicycle. The vehicle that Ahmed was riding on meets the definition of a moped set forth by MGL 90/1, specifically that it's top seed was not in excess of 30 MPH. According to the owners manual that I found on line the top speed for the Lectric XP is 20 MPH. Ahmed stated that he believed that north bound traffic on Lexington St had a green light but he could not be sure. Ahmed also stated that he was unfamiliar with the area and it traffic patterns. Ahmed stated that he saw Robidoux vehicle and thought it would stop. Ahmed stated that at the time of crash be estimated that he was travailing approximately 12 MPH. Ahmed was transported via EMS to Newton Wellesley Hospital form treatment of lacerations to his hands, legs and possible internal injuries. During the investigation of this crash I discovered via the MA RMV data base that Ahmed's driver's licenses was suspend on 10/05/2020 as a part of a CWOF for 90/24 OUI . Ahmed is on active probation of out Natick Distinct Court until 09/24/2021. Under Comm v. Lopez 91 Mass App. Ct. 485 ( 2017 ) the charge for operating a moped with a suspended license should be charged as 90/10 , operating with out a license as opposed to 90/23 operating with a suspended licenses. Under MGL 90/1d moped must have one number plate issued by the MA RMV , and Ahmed's moped did not. I took photos of Robidoux's vehicle and of Ahmed moped and the disk was downloaded by the NPD's IT Bureau. Based upon statements made to me as well as information from the MA RMV data base I issued Ahmed MA Criminal Application T2015903 and cited him for MGL 90/10, operating with out a license, 89/9 failure to stop for a red light and 90/1d, unregistered moped.
Report
url:
url:
Case
number:
limit:
Violation
cited:
On 11/10/20 I was working N492 when I responded to the area of Albemarle Rd. at Crafts St. for a 2 car MVA. Upon arrival I spoke with the Operator of Veh 2 Jane Connor. Connor stated she was traveling southbound on Albemarle Rd. when she came to the stop sign at Crafts St., which she came to a complete stop at. However she believed she had enough time to get across the intersection and pulled into the roadway causing a collision with Veh 1. Connor stated it was her fault and she had misjudged the distance and speed of Veh 1. I then spoke with the operator of Veh 1 Tessa Lanfear. Lanfear stated while traveling east bound on Crafts St. Veh 2 Pulled out of Albemarle Rd. into the roadway in front of her causing a collision. Todys responded and towed Veh 2 at the owners request. Newton Medics obtained patient refusals for all parties involved. All parties were provided with a crash report number.
Report
url:
url:
Case
number:
1230 COMMONWEALTH AVE
limit:
Violation
cited:
Report
url:
url:
Case
number:
1231 WASHINGTON ST
limit:
Violation
cited:
Report
url:
url:
Case
number:
483 CENTRE ST
limit:
Violation
cited:
On 12/3/2020 at 1400hrs I investigated a past motor vehicle crash involving a pedestrian. The crash occurred on 12/03/2020 at approximately 1240hrs. The crash was located in the area of 483 Centre St. Centre St is a public way in the city of Newton. Vehicle 1 was traveling southbound on Centre St near the area of 483 Centre St. Pedestrian 1 was located on the southbound side of Centre St near 483 Centre St. Pedestrian entered the southbound lane of Centre St and was struck by Vehicle 1. As a result of the impact Pedestrian 1 sustained a minor injury to his left leg. Vehicle 1 had no known damage. No parties were transported. No tow was required. It should be noted that the crash was reported by the Operator of Vehicle 1 Daniel Zandman at approximately 1400hrs. Zandman states that he was operating his Vehicle southbound on Centre St just after the intersection at Church St. Zandman states that Pedestrian 1 unexpectedly ran in front of his vehicle. Zandman stated that he did not have enough reaction time to come to a complete stop and his front bumper made contact with Pedestrian 1. Zandman stated that after impact he immediately got out of his vehicle and checked on Pedestrian 1. Zandman described pedestrian on as a 10 year old white male identified as Dexter Jagoditish. Zandman stated that while on scene Dexter called his mother Jess Jagoditish who immediately responded to the scene. Zandman stated that he exchanged information with Jess Jagoditish who then took Dexter home. Zandman states that a witness Mia Martin was also on scene. At approximately 1425hrs I called and spoke to Dexter and his mother Jess Jagoditish. Dexter states that he was walking on the sidewalk near 483 Centre St. Dexter states that he wanted to cross Centre St and thought there were no cars coming. Dexter stated that he entered the southbound lane of Centre St and a car came out of no where and hit him. I then spoke to Jess Jagoditish who is Dexter's mother. Jess stated that she received a call from Dexter around 1240hrs stating he was just hit by a car. Jess stated that when she arrived on scene Dexter was with Zandman and a witness Mia Martin. Jess stated that both Zandman and Martin explained them what had happened. Jess stated that Dexter appeared to be ok so she decided to take him home. Jess states that at this time Dexter has a bruise on his left calf but otherwise appears to be ok. At 1551hrs I spoke with the witness Mia Martin. Martin states that just prior to the crash she was walking her dog behind Dexter. Martin states that "out of nowhere" Dexter sprinted into the southbound lane of Centre St. Mia states that she then observed Vehicle 1 attempt to slow down and swerve to the lest to avoid Dexter. Mia states that the passenger side front bumper then made contact with Dexter. Mia states at impact Vehicle 1 was traveling at a very slow speed. Mia states that Dexter was then knocked on to the ground but then immediately jumped up and started to run away. Mia states that both she and Zandman were able to get Dexter to comeback so that they could check to see if he was ok. Mia states that Dexter was then able to contact his mom who responded on scene. Due to this crash being reported after the fact, Fire, EMS or Police where not initially notified and did not respond to the scene. Pictures were also not taken of the crash scene. At this time this report is for documentation purposes. After speaking with all the parties involved it appears that the crash was caused by Pedestrian 1 entering the roadway in a manner which gave Vehicle 1 little or no time to react.
Report
url:
url:
Case
number:
200 NAHANTON ST
limit:
Violation
cited:
VEHICLE OPERATOR WAS TRAVELING STRAIGHT AHEAD ON NAHANTON ST, HEADING WESTBOUND. HE STATES THAT HE WAS GOING THE LEGAL SPEED LIMIT. HE VEHICLE SKIDDED OUT OF HIS LANE, SIDESWIPED A TREE ON THE OPPOSITE SIDE OF THE ROAD. AND TOOK OUT A COUPLE SECTIONS OF FENCE AT THE CHARLES RIVER COUNTRY CLUB. NO INJURIES REPORTED, VEHICLE TOWED BY TODYS TOWING OF NEWTON CHARLES RIVER COUNTRY CLUB WAS NOTIFIED BY MYSELF VIA VOICEMAIL OF THE DAMAGE TO THEIR PROPERTY.
Speed, Tree
Report
url:
url:
Case
number:
DEDHAM ST & GREENWOOD ST
limit:
Violation
cited:
Operator 1 of Vehicle 1 stated they were stopped at the stop sign on Greenwood St (s/b) and was attempting to turn left (e/b) on Dedham St when she collided with vehicle 2. Operator 1 said she believed vehicle 2 was going faster than the speed limit. Moderate damage to vehicle 1, towed by todys. No injuries to operator and passenger of vehicle 1. Operator 2 of vehicle 2 said he was driving w/b on Dedham St when vehicle 1 was taking a left and tried to avoid vehicle 1 and could not and the two cars collided. Operator 2 stated he did not have a license. Minor damage to vehicle 2. No injuries to operator 2 or any of the passengers in vehicle 2. Operator 2, Gabriel Mesquita was issued in hand ma citation T2014680 for c90s10 Operating without a license.
Citation, Moderate, Speed
Report
url:
url:
CREATE TABLE "crash_reports" ( [case_number] TEXT PRIMARY KEY, [datetime] TEXT, [date] TEXT, [time] TEXT, [address] INTEGER, [street1] TEXT, [street2] TEXT, [intersection] INTEGER, [speed_limit] INTEGER, [hit_run] INTEGER, [violation_cited] INTEGER, [narrative] TEXT, [keywords] TEXT, [dcc] TEXT, [dcc_code] TEXT, [report_url] TEXT, [image_url] TEXT , [geocoded_address] TEXT, [latitude] TEXT, [longitude] TEXT, [manual_geocode] INTEGER, [retrieved] TEXT);
